Use a txt file (X, Y, Z), with random values for X and Y, to get a new file X and Y |
Abdelhai
Rep Power: 0 ![]() |
I have a big 3D geometric txt file (X, Y, Z), about 50k lines, but it's not perfectly structured, I mean X and Y are picked at random. I want to create a new file based on the data of the first file, where the values of X and Y are predefined, so the program calculates the new values of Z, and then the program creates a new text file.
Thanks in advance! |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
What do you want to do exactly? It's too vague.
Have you tried using a text editor or microsoft excel or well, anything? |
#3 | |
Abdelhai
I used Microsoft Excel to sort in ascending or descending order...but because of the large number of lines it takes a long time In another way, is there a possibility to find Z-values from a 3D representation (X, Y, Z) given constant values of X and Y as an iterative matrix? |
If I understand what you mean, Octave and Matlab have sortrows, where you can instruct them to sort the rows of a matrix according to the columns of your choice in the order of your choice. Then you can write the output back to a txt file in the new order.
c++, fortran |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
