Scale down difference in results legends
Old   June 28, 2022, 05:18
Default Scale down difference in results legends
haider ali
haider11 is on a distinguished road
Can anybody help me on this?
Description= There is a rotating cylinder filled with gas and liquid is coming in from 6 static liquid nozzles. The liquid vof is 1 at the nozzle inlet.
Problem facing: when I plot the liquid vof contour results, the contour does not show difference becuase there is significant difference bewteen the values in cylinder (vof= 0.004) and nozzle (vof =1), first image.
I clipped the values manually in the contour legends to show the difference clearly, Figure 2. Is there any other reliable way to do it, since I am missing some values,
Thanks
Ali
haider11 is offline   Reply With Quote
What to Do When There is a Large Scale Difference in Geometry? (too large/small dom.) yanqoue CFX 13 June 24, 2019 19:20
difference between turbulent Dissipative length and integral length scale arun1994 Main CFD Forum 1 August 1, 2018 13:26
The results difference between parallel and serial run. Hkp OpenFOAM Running, Solving & CFD 2 April 17, 2014 02:26
Difference in pressure drop results To all fluent users need help pls FLUENT 4 May 30, 2007 04:31
Difference in pressure drop results al-jasim FLUENT 0 May 28, 2007 09:54
