Turbine Nozzle Wake
Old   July 20, 2000, 12:03
Default Turbine Nozzle Wake
McCarthur, J.
Hi Gentlemen,
Does anybody know who has ever invesitgated the wake characteristics (from the upperstream nozzle) at the downstream of the rotor of the same turbine stage? I am measuring these using 3D hot wire, I need some references. Thanks.
J.M.
Old   July 20, 2000, 12:55
Default Re: Turbine Nozzle Wake
John C. Chien
(1). Check into the publications by Penn State researchers published in ASME/Journal of Turbomachinery. They have done some cfd analysis and testing(?).
Old   July 20, 2000, 15:33
clifford bradford
Yes John is correct. Penn State researchers have done a lot of experiments of this sort. Search for author name Lakshminarayana. you can also contact Dr. Lakshminarayana at the Aerospace Department of Penn State. the work was done by his graduate students. you will also be able to find some multistage CFD work in ASME journal of turbomachinery as well
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
Wind turbine wake effect caohan FLUENT 0 October 8, 2010 07:54
Setting up a turbine nozzle case cfdengineer CFX 2 August 2, 2010 05:49
Frozen Rotor and Wake of a Wind Turbine Peter CFX 0 June 26, 2006 15:12
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
