November 26, 2021, 05:03 |
openfoam vs starccm+
Březňák
Rep Power: 5 |
I used OpenFOAM for two years and I just changed my employer recently. I participated OpenFOAM courses at ESI and I prefer to use it. But here colleagues use almost only Star-CCM+, maybe because here is automotive company. So, I am learning Starccm+ for two weeks. But it looks like that the starccm has often problem due to license and once it happened something weird that I surely saved the setup and in several hours I could find that it was not saved and the old false setup was still there. When I open a huge mesh data, it takes too long time to save, even I changed some boundary conditions. And I personally think the trees(?) on left side are too unnecessarily complicated, so it makes the setup more unclearly. Still I cannot understand but why a lot of companies use commercial programs even there is strong open source solver like OpenFOAM. Maybe because of geometry clean up? But here uses also ANSA for that. |
November 26, 2021, 06:14 |
#2 | |
Arjun
Rep Power: 34 |
Your post shows that you are just new to starccm and you are little bit confused about workflow. Edited to add: Do help him Compressible nozzle flow - no problem for fluent but impossible with openFOAM? |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Solvers in OpenFOAM for LES + heat transfer | arun1994 | Main CFD Forum | 1 | November 26, 2021 07:57 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
