Solvers in OpenFOAM for LES + heat transfer
Old   November 24, 2021, 15:07
Default Solvers in OpenFOAM for LES + heat transfer
Arun subramanian
arun1994 is on a distinguished road
Hello!
I am trying to run a film cooling simulation in openfoam using LES. All the tutorials I have seen so far are cold flows without changes in temperature. I would like to know if there is a 'sample test case' for forced convection problems. I have some nice results with RANS but I am struggling with LES. Is there a solver that works best for these types of problems?
In the case below, I have some velocity field in the flow but no changes in the temperature field with time...
I am pretty sure that I am missing something blatantly wrong. Would be nice if someone could point it out please!
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (10 0 0);
boundaryField
    Body_5.Inlet
        type            surfaceNormalFixedValue;
        refValue        uniform -10;
    Body_5.Inlet_coolant
        refValue        uniform -10.68323;
    Body_5.Basewall
        type            noSlip;
    Body_5.side2
        type            noSlip;
    Body_5.Top
        type            noSlip;
    Body_5.Side1
        type            noSlip;
    Body_5.Outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
    Body_5.Wall_coolant
        type            noSlip;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293;
boundaryField
    Body_5.Inlet
        type            fixedValue;
        value           uniform 293;
        type            fixedValue;
        value           uniform 313;
    Body_5.Basewall
        type            zeroGradient;
    Body_5.side2
        type            zeroGradient;
    Body_5.Top
        type            zeroGradient;
    Body_5.Side1
        type            zeroGradient;
    Body_5.Outlet
        type            inletOutlet;
        value           $internalField;
        inletValue      $internalField;
    Body_5.Wall_coolant
        type            zeroGradient;
     \\/     M anipulation  |
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
    Body_5.Inlet
        type            zeroGradient;
        // type            mixed;
        refValue        uniform 101325;
        refGradient     uniform 0;
        valueFraction   uniform 0.3;
        type            zeroGradient;
        // type            mixed;
    Body_5.Basewall
        type            zeroGradient;
    Body_5.side2
        type            zeroGradient;
    Body_5.Top
        type            zeroGradient;
    Body_5.Side1
        type            zeroGradient;
    Body_5.Outlet
        type            fixedValue;
        value           uniform 101325;
        // type            mixed;
        // refValue        uniform 110000;
        // refGradient     uniform 0;
        // valueFraction   uniform 1;
        // type            transonicOutletPressure;
        // U               U;
        // phi             phi;
        // gamma           1.4;
        // psi             psi;
        // pInf            uniform 110000;
    Body_5.Wall_coolant
        type            zeroGradient;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    Body_5.Inlet
        type            calculated;
        value           uniform 0;
        type            calculated;
        value           uniform 0;
    Body_5.Basewall
        type            nutkWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    Body_5.side2
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    Body_5.Top
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    Body_5.Side1
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    Body_5.Outlet
        type            calculated;
        value           uniform 0;
    Body_5.Wall_coolant
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alphat;
dimensions      [1 -1 -1 0 0 0 0];
boundaryField
    Body_5.Inlet
        type            calculated;
        value           uniform 0;
        type            calculated;
        value           uniform 0;
    Body_5.Basewall
        type            compressible::alphatWallFunction;
        Prt             0.85;
        value           uniform 0;
    Body_5.side2
        Prt             0.85;
        value           uniform 0;
    Body_5.Top
        Prt             0.85;
        value           uniform 0;
    Body_5.Side1
        Prt             0.85;
        value           uniform 0;
    Body_5.Outlet
        type            calculated;
        value           uniform 0;
    Body_5.Wall_coolant
        Prt             0.85;
        value           uniform 0;
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType  LES;
LES
    LESModel        Smagorinsky;
    turbulence      on;
    printCoeffs     on;
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    PrandtlCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Cdelta          0.158;
    vanDriestCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Aplus           26;
        Cdelta          0.158;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        nMoles      1;
        molWeight   28.9;
    thermodynamics
        Cp          1007;
        Hf          0;
    transport
        mu          1.8e-05; //1.2 kg/m^3 x 1.5e-05 m^2/s
        Pr        1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(p|rho)"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-6;
        relTol          1e-4;
    "(p|rho)Final"
        $p;
        relTol          0;
    "(U|k|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          1e-6;
    "(U|k|nuTilda)Final"
        $U;
        relTol          0;
    e
        tolerance       10;
        relTol          1;
    eFinal
        tolerance       10;
        relTol          1;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 2;
    nCorrectors     2;
    nNonOrthogonalCorrectors 1;
    rhoMin          1.2;
    rhoMax          1.2;
relaxationFactors
    equations
        ".*"  1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      Gauss filteredLinear;
    div(phi,e)      Gauss linear;
    div(phi,K)      Gauss linear;
    div(phiv,p)     Gauss filteredLinear;
    //div(phi,k)      Gauss linear;
    div(phi,B)      Gauss linear;
    div(phi,muTilda)Gauss linear;
    div(B)          Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     rhoPimpleFoam;
//startFrom       startTime;
startFrom    latestTime;
startTime       0;
//stopAt          writeNow;
stopAt        endTime;
endTime         5000000;
deltaT          1e-05;
writeControl    runTime;
writeInterval   4e-04;
purgeWrite      10;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
runTimeModifiable true;
libs ("libLEMOS-2.4.x.so");
functions
    /*probes
        type probes;
        functionObjectLibs ("libsampling.so");
        enabled true;
        outputControl timeStep;
        outputInterval 1;
        probeLocations
            (0.0738 0.0015 0.0)
            (0.0738 -0.0015 0.0)
        fields
            U
    fieldAverage
            type            fieldAverage;
            functionObjectLibs ("libfieldFunctionObjects.so");
            enabled         true;
            outputControl   outputTime;
            fields
                    U
                mean on;
                prime2Mean on;
                base time;
            nut
                mean on;
                prime2Mean off;
                base time;
arun1994 is offline   Reply With Quote
Old   November 26, 2021, 07:57
JT
jt_turbo is on a distinguished road
Check my former lab's validation cases: https://github.uconn.edu/CTF-UConn/chtValidationCases
jt_turbo is offline   Reply With Quote
film cooling, heat transfer, les, openfoam 7, rhopimplefoam
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 21:42
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Conductive Heat Transfer in OpenFoam? FloK OpenFOAM 8 March 18, 2011 13:51
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
