In Fluent meshing after changing the angle of the created body the mesh doesn't maps |
March 7, 2022, 06:16 |
SivaG
Rep Power: 4 |
I have 2 problems here
1. The created geometry has many free faces even I repaired the model using space claim it still shows free faces, then I diagnosed it in fluent meshing itself but still have few left, how do i clear them. Like is there any local methods to clear those free faces. 2. After rotating the model using the rotate option available in fluent meshing the mesh created becomes non conformal so how do I match these nodes for getting a adaptive mesh even after the rotation of the mesh. By the way I have 2 zones connected to each other. Thanks in advance for your valuable time. |
cfd - post, fulent meshing, meshing 3d, rotating mesh |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent | teguhtf | ANSYS Meshing & Geometry | 0 | January 24, 2019 22:04 |
Updating Fluent after meshing from Worbench Scripting, asks to update mesh again. | UchihaMadara | FLUENT | 0 | January 8, 2018 14:18 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
