March 1, 2022, 20:05 |
Xflow question
Rep Power: 4 |
For the exactly same shape geometry, Why simulation is very slow when it's small(centimeter), but fast when large(meter)?
Xflow to simulate a fan. |
March 2, 2022, 05:24 |
M
Rep Power: 12 |
How is it the same geometry, if its once small and once big?
A too general answer to a too general question: Probably it results in different mesh sizes with whatever parameters you use for the meshing and thus, simulation time differs. |
March 2, 2022, 07:40 |
#3 | |
Rep Power: 4 |
Second time, imported the geometry by meter unit, then simulated. Every parameters are the same. Except Resolved scale times 100. |
March 3, 2022, 02:46 |
M
Rep Power: 12 |
My reply was aimed to get you to investigate your setup more thoroughly and tell us what you are doing. With the information provided, it is just guessing:
* what do the meshes look like (cell count, quality, ...) * what equations are solved, models used * are the results similar, are important quanities converging? Have a look how other people here describe their cases. Guide: How to ask a question on the forums |
March 3, 2022, 07:50 |
Rep Power: 4 |
I attached a very simply example to explain this question.(if I attached them correctly)
Xflow.zip contains 2 project files: "Cylinder100.xfp, Cylinder100.lay" is the large one, "dm.png" tells its time. "Cylinder.xfp, Cylinder.lay" is the small one, "mm.png" tells its time. I just wish to learn the reason for the obvious difference. |
March 3, 2022, 08:40 |
M
Rep Power: 12 |
Most people, including me, on this forum are not in possession of that particular software, so unfortunately this does not help.
March 3, 2022, 15:09 |
#7 | |
Arjun
Rep Power: 34 |
Assuming x flow is lattice boltzmann method, by changing the grid length ie from meter to cm you are now solving the problem at different Reynolds number because viscosity is computed from the size of the domain. Thats why now the time to simulate has changed, |
March 3, 2022, 23:04 |
#8 | |
Rep Power: 4 |
I try to catch your point. Does it mean domain size ↓, viscosity ↑, Reynolds number ↓, time ↑ ? |
March 5, 2022, 02:35 |
#9 | |
Arjun
Rep Power: 34 |
There is a paper about it: https://www.semanticscholar.org/pape...7321d72aeceaaf Numerical Viscosity of Finite Difference Lattice Boltzmann Method S. Mizutani, M. Tsutahara Published 2006 Physics, Mathematics Transactions of the Japan Society of Mechanical Engineers. B The difference of the influence of numerical viscosity between the Navier-Stokes based finite difference method and the finite difference lattice Boltzmann mathod is shown. In order to stabilize calculation, upwind schemes with numerical viscosity is generally used in the finite difference lattice Boltzmann method. The influence of numerical viscosity is dependent on a Mach number. The dependence to the direction of the flow of numerical viscosity is small as compared with the Navier-Stokes based finite difference method. Edited to add: Interestingly this was pointed to me by Tsutahara san himself when he was trying to clear some of my doubts. |
March 5, 2022, 09:37 |
#10 | |
Rep Power: 4 |
Frankly speaking, the paper is some difficult for me. So, this difference of simulation speed is normal, neither xflow problem, nor my mistake? |
March 5, 2022, 12:43 |
#11 | |
Arjun
Rep Power: 34 |
I had difficulty understanding the viscosity since in lattice boltzman you really do not specify it. It is an outcome of three main things 1. Time Step 2. Relaxation Parameter 3. The advection method used. You are not doing anything wrong, what you are seeing is what is to be expected. |
March 7, 2022, 07:59 |
#12 |
Rep Power: 4 |
Thank you, arjun and AtoHM, very much!
I learned much these days. And I hope get along with xflow. |
A question about XFlow boundary conditions | mmkcfd | Main CFD Forum | 0 | April 11, 2015 03:47 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
