Should prop wake dissipate before reaching outlet domain? (Transient)) |
March 8, 2022, 00:19 |
Varun V P
Rep Power: 5 |
We are simulating some test cases for a propeller, which requires that we do a transient simulation. The common advice on sizing of the mesh is that the pressure outlet should be far enough so that the wake dies out before it reaches it. But since this is a transient simulation, it takes a lot of time steps for the wake to fully reach the outlet. And even when it is doing so, I notice on my lift and drag monitors that the forces are converged. Therefore, I was thinking if I should run a steady state simulation first, wait for wake to fully develop, and then switch to transient? |
March 8, 2022, 04:16 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Well, it depends on what you really want to simulate. Let me clarify: 1) you want to simulate the whole transient, that is the flow problem starting from some suitable physical initial and boundary conditions. 2) you are interested only in the final fully developed unsteady flow when an equilibrium is reached. Clearly, only case 2 can be started from arbitrary initial conditions and you can use a converged steady solution. Be aware that, depending on the formulation you are using (DNS/LES/DES/URANS) the things can be more complex. |
March 8, 2022, 07:57 |
#3 | |
Varun V P
Rep Power: 5 |
So when I go with case 2, if I understand correctly, the steady state simulation will converge with a full wake, which the transient simulation will finally refine. Am I correct? |
propellers, transient 3d, wake modeling |
Calculating fluid recirculation at an outlet in transient analysis | HeatK | CFX | 3 | November 4, 2020 14:33 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
OUTLET in domain | billow | Phoenics | 1 | April 10, 2006 04:11 |
