Interfaces and boundaries in Star CCM+
Old   April 15, 2022, 04:31
Default Interfaces and boundaries in Star CCM+
Boaz ruis
boazruis is on a distinguished road
Hello everyone,
Im currently trying to investigate the effect of an air scoop on radiator flow performance for a car. However, i'm running stuck on inplementing the radiator/fan. I want to use a porous region as to simulate the pressure drop over the rad (i have already proved that this is an accurate representation) and a fan interface to simulate the fan. Right now i'm gettting stuck on defining the boundaries/regions/interfaces needed to get this to work. If i just draw a windtunnel over the rad it acts like it doens't exists in the simulation. However if i extract the radiator/parts from the windtunnel (in siemens nx, i dont quite understand how the extract geometry function works in star ccm) i get a lot of problems with interfaces/duplicate faces etc.
Does anybody know how to do this effectively?
I've added some pictures to clarify.
Sincerely Boaz
https://imgur.com/a/ilOWj4s this is the tunnel simply drawn around the radiator block
https://imgur.com/a/I4sQNm4 a setup that does work, where the radiator is not fully encapsulated by the windtunnel, and a picture of the radiator/fan package i need to simulate
boazruis is offline   Reply With Quote
Mesh generation: split boundaries in group of interfaces Byba Mesh Generation & Pre-Processing 1 May 28, 2019 15:11
[ANSYS Meshing] Mesh generation from Ansys: split boundaries in group of interfaces Byba ANSYS Meshing & Geometry 3 May 28, 2019 15:00
Error by creating interfaces for Multiple Regions – Heat Transfer Sakuyalex STAR-CCM+ 3 March 22, 2018 04:16
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 anttiad9000 OpenFOAM Running, Solving & CFD 3 March 2, 2016 19:37
2D Rotating Detonation Engine Periodic Boundaries whitet86 FLUENT 2 June 25, 2015 11:04
