July 14, 2022, 06:10 |
air-dust flow setting
jisu
Rep Power: 3 |
hello,
I want to simulate air-dust(solid , 1500kg/m^3) multiphase flow. At t=0, the chamber has a uniform dust concentration. After that, I want to see how much the dust decreases over time. but Fluent's multiphase(mixture) doesn't seem to be gas-solid. and Discrete Phase(injection) cannot specify a volume fraction(I used the volume fraction to set the uniform concentration.) what can i do to set DPM to start at a uniform concentration in the room instead of injection? ( = 0s -> All points have the same concentration and not generate dust, 60s -> Concentration decreases as particles are collected at the outlet) Let me know if you have an alternative.. Thanks for reading and have a nice day |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 20:05 |
Setting up a case for a plane plate in a longitudinal flow | Chronique | OpenFOAM Running, Solving & CFD | 0 | October 9, 2014 14:17 |
HELP!!! Indoor air flow pattern | Peter Zhang | Main CFD Forum | 4 | November 3, 1999 02:49 |
