K omega SST vs Realizable K epsilon
Old   August 7, 2022, 11:26
Default K omega SST vs Realizable K epsilon
Ahmad Hijazi
AhmadHij is on a distinguished road
Greetings,
I am working on a 2D transient simulation of vertical axis wind turbine. here are some of the Dimensions:
Diameter =2 m
Chord=0.265 m
Number of blades=2
pitch angle=6 degrees
airfoil: NACA 0021
Boundary conditions :
inlet velocity=8 m/s
turbulence intensity=0.5%
Reynolds number is around 10^5.
I tried first the K omega SST turbulence model, and it gave very low results in comparison with the experimental data (by comparing the average Cp value), so I then tried the Realizable K epsilon model, and It gave much better results.
My question is can I use the Realizable K epsilon model for vertical axis wind turbines where there are a lot of flow separation and why it is giving much better results than K omega SST model ?
AhmadHij is offline   Reply With Quote
Old   August 7, 2022, 14:22
Administrator
jola's Avatar
Jonas Larsson
jola is on a distinguished road
Send a message via MSN to jola Send a message via Skype™ to jola
The SST k-omega model often predict separation on convex surfaces too early. If your operating point has significant suction-side separations then the SST k-omega model will probably predict too early separations and thereby incorrect Cp values.
Your Reynolds number is quite low and you will probably have a fairly large laminar part of your suction-side boundary layer. This will make the separation problem even worse.
Using a Relizable k-epsilon model can improve the results. If you have experimental data for a similar case you should use that to decide which turbulence model to use.
Another way to improve the results is to use a transition model, but since you have so low turbulence levels this is a bit tricky since you might have natural transition and not by-pass transition caused by the free-stream turbulence.
jola is offline   Reply With Quote
komega sst model, realizable k-epsilon, vawt wind turbine
Setting change from k omega to k omega SST bingo641 OpenFOAM Programming & Development 0 May 22, 2018 05:15
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 06:44
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 13:06
problem from k epsilon to k omega NJG OpenFOAM Running, Solving & CFD 0 April 15, 2013 08:24
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
