December 19, 2012, 06:27 |
sutherland temperature computing
Meimei Wang
Rep Power: 15 |
May I ask how to compute sutherland temperature? Shall I always use 110 K? Thank you very much.
Best regards, Meimei |
December 20, 2012, 00:17 |
Rep Power: 13 |
In my solver for air properties I use:
mu = C1*pow(T, 3/2)/(T+C2) k = C3*pow(T, 3/2)/(T+C4) where; 1.458e-06 !C1 - Sutherland's Law Dynamic Viscosity Constant 110.4 !C2 - Sutherland's Law Dynamic Viscosity Constant 2.495e-03 !C3 - Sutherland's Law Thermal Conductivity Constant 194.0 !C4 - Sutherland's Law Thermal Conductivity Constant I am also curious if there are better values to be using based on the temperature ranges I am simulating... |
May 25, 2022, 05:26 |
Lukas Fischer
Rep Power: 7 |
OpenFOAM and ANSYS Fluent use T_s = S = C2 = 110.4 K for air. However, in the paper of Sutherland it gives a value of 113 K. Where does the difference come from? The value of 110.4 K is not even mentioned. Paper of Sutherland: https://www.google.com/url?sa=t&rct=...GPpKK5dGrLzoaL |
May 25, 2022, 08:33 |
Lucky
Rep Power: 66 |
I don't know the origin of any of those numbers but to me, if I am just trying to calculate viscosity then Sutherland's formula is just the form of the equation and I never have any expectation that there is 1 set of correct coefficients unless I am writing specifically about the history of the viscosity of air. The difference is expected (at least in my opinion).
Sutherland's formula doesn't take into account pressure and is really just a curve fit of the viscosity vs temperature at some arbitrarily set reference temperature (which is also one of the coefficients). Best accuracy is obtained when the curve fitting is done at the reference temperature and pressure that you are simulating. If I am doing combustion at 24 bar, I wouldn't use a set of Sutherland's coefficients at room temperature and pressure, I would do my own curve fitting and generate my own coefficients vs a fluids database that I trust. Also, fluid properties databases have changed significantly since the time of Sutherland. |
May 25, 2022, 09:35 |
Lukas Fischer
Rep Power: 7 |
I think you are right. It is better to use your own function derived from a property tool.
I compared the results of a property tool and sutherland with both coefficients and the results are very similiar in the temperature and pressure range I have. Good to check, though. |
problem during my computing | oliver | FLUENT | 0 | May 31, 2007 08:35 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | CFX | 4 | June 27, 2006 04:39 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Main CFD Forum | 1 | June 25, 2006 14:25 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Fidelity CFD | 0 | June 24, 2006 18:23 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | FLUENT | 0 | June 24, 2006 18:22 |
