August 11, 2022, 10:17 |
Rotor-Stator cavities - cfd
Nazım
Rep Power: 3 |
Two compressor rotor-stator cavities are given in attachment. The flow direction of the air in the compressor is also indicated by the arrow.
Can you explain the flow and physical effects in these cavities? For example: Where does the flow enter and exit the cavities? What is the characteristic of the flow in the cavity? Ex. Is there a circulation or does the flow proceed uniformly inside the cavity? If circulation is happening, in what direction? What is the element circled in red and its function? If you wanted to model the flow here in CFD, what setup would you set up, e.g. What would be the entrance-exit boundary conditions, the boundary conditions to be used on the wall, the turbulence model? Is it necessary to model heat transfer on the wall? Last edited by ocb; August 22, 2022 at 07:45. |
cavity, compressor, rotor-stator |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 12:23 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
