November 6, 2022, 21:29 |
Openfoam simulation crash
harshavardhan
Rep Power: 8 |
My simulation is getting crashed and throwing the following error. If any one could guide me would be really helpful.
Loading OpenFOAM/2112 Loading requirement: openmpi/4.1.2 /local/spool/pbs/mom_priv/jobs/62925630.gadi-pbs.SC: line 11: cd: /scratch/hy4/hk3956/1sec: No such file or directory [0] [0] [0] --> FOAM FATAL ERROR: (openfoam-2112) [0] sprayFoam: cannot open case directory "/scratch/nd25/hk3956/5sec/processor0" [0] [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [0] [0] [0] --> FOAM FATAL ERROR: (openfoam-2112) [0] No times selected [0] [0] From int main(int, char**) |
January 1, 2023, 04:04 |
Rep Power: 11 |
Check decompositionPar log.
Also post more info on what you're tying to do. |
January 1, 2023, 13:58 |
#3 | |
Will Kernkamp
Rep Power: 12 |
I underlined the two directories shown in your file. It appears that your run setup is inconsistent because the two directories are not compatible in the OpenFOAM directory structure. |
February 2, 2023, 00:11 |
harshavardhan
Rep Power: 8 |
thank you for the reply. I fixed the issue.
Why the change of writeInterval will cause simulation crash? | kclement1993 | OpenFOAM Running, Solving & CFD | 1 | March 26, 2020 16:42 |
OpenFoam - Simulation suddenly stops, reactingFoam | Vittorio94 | OpenFOAM Programming & Development | 2 | June 25, 2019 03:02 |
OpenMPI error at the beginnin of parallel OpenFOAM Simulation | tre95 | OpenFOAM Programming & Development | 2 | June 17, 2019 06:36 |
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days | joegi.geo | OpenFOAM Announcements from Other Sources | 0 | October 1, 2016 19:20 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
