November 6, 2022, 12:32 |
Reynolds number for tube bank
StanPH
Dear all,
I'm doing heat transfer simulations of an in-line tube bank that has cylindrical tubes. When reading articles, some authors compute the Reynolds number based on the tube diameter and maximum velocity between the tubes. Other authors use inlet velocity and some of them compute the Reynolds number based on the inlet hydraulic diameter. How can I find out if there is "low" or "high" Re to choose appropriate computational model? Re based on the tube diameter and maximum velocity can be "low", while Re based on the inlet parameters can be "high" at the same physical parameters. Thank you. |
November 6, 2022, 13:14 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
All choices produce a congruent non dimensional Re number. The key is to use the correct characteristic lenght and velocity that make the term in the non dimensional equation of O(1). In principle, the mean inlet velocity and the diameter of the tube would produce the correct Re number. |
November 9, 2022, 11:21 |
#3 | |
StanPH
Thank you. Is the mentioned approach applicable also for a channel with tubes inside? What if the tubes have different diameters? |
November 9, 2022, 11:55 |
Rep Power: 71 |
hydraulic diameter, reynolds number, tube bank |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Boundary condition problem (Freestream) | KAYANO | OpenFOAM Running, Solving & CFD | 5 | June 1, 2021 05:57 |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
