Pressure from Particle Image Velocimetry Measurements
Old   November 28, 2022, 09:37
Default Pressure from Particle Image Velocimetry Measurements
E
IbizaFR is on a distinguished road
Hello to everyone,
I got the instantaneous 2D velocity measurements from Particle Image Velocimetry inside the region of a hydraulic jump.
I want to calculate the mean time pressure field from the mean time velocity measurements by the numerical solution of the Reynolds averaged Poisson Pressure equation.
I solve the resulting system with the Jacobi method but the iterative algorithm does not converge as the absolute difference between the updated pressure field and the pressure field calculated from the previous iteration is not getting smaller.
Any ideas for the problem ?
Thank you.
IbizaFR is offline   Reply With Quote
Old   November 28, 2022, 17:20
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by IbizaFR View Post
Hello to everyone,
Thank you.
Could you give the details? I suppose you want to solve
Div Grad p = source,
the LHS being in your case?
But to state the full Poisson problem you need to prescribe the BCs, how did you prescribe that?
Are you working on a cartesian structured grid?
FMDenaro is online now   Reply With Quote
Old   November 29, 2022, 05:00
E
Yes I want to solve Div Grad p=source. The equation follows the Reynolds average approach, so Poisson equation for pressure also contains the Reynolds shear stress terms in the RHS.
All BCs are Newmman conditions regarding the grad(p) calculated from the two dimensional Reynolds averaged Navier Stokes equations.
I work on a cartesian structured grid which is the same with the grid that the velocity has been measured with PIV.
Old   November 29, 2022, 05:06
Tu ensure convergence of an iterative method, you have to fulfill the compatibility condition. Thus, I suppose you prescribed the Neumann conditions in a non correct way.
Check for similar discussions in this forum.
Old   November 30, 2022, 06:43
E
Please can you propose me papers regarding the compatibility condition ?
Thank you.
Old   November 30, 2022, 08:43
Thank you.
That is a classic topic in mathematical anaysis of PDE. Just search on Google:
https://www.google.com/search?client...eumann+problem
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 05:40
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 18, 2018 23:39
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 16:30
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
