Wall functions for y+ < 1
Old   December 9, 2022, 14:10
Default Wall functions for y+ < 1
Yicong
y.liu is on a distinguished road
Hi guys,
I'm trying to run an LES Smagorinsky simulation where my average y+ is 0.74 and my max y+ is 2.
These are low y+ values, so I've read that I don't need a wall function.
Is there any reason why I shouldn't use a wall function (nutUSpaldingWallFunction for example), since it gives me accurate results anyway?
y.liu is offline   Reply With Quote
Old   December 10, 2022, 04:34
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
I don't remember the details for OF wall functions but, if a wall function is an all y+ one then, for low y+ values it just behaves as if it was off.
For the static Smagorinsky model, you should also check that OF has some damping function near walls for the turbulent viscosity, as it is known to produce the wrong near wall behavior.
These aspects could or not actually be relevant for your case depending from how important the wall turbulence production is in the overall flow mechanism at play. This, in addition to the discretizazion, of course.
sbaffini is offline   Reply With Quote
low y+, wall functions
Ansys CFD-Post Application Error rushiCFD FLUENT 0 March 21, 2021 07:51
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 16, 2020 23:44
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 10:11
wall functions implementation besh OpenFOAM Programming & Development 0 January 1, 2013 09:14
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
