setting boundary inlet turbulence conditions in code saturne |
January 4, 2023, 01:41 |
vesvard
Rep Power: 3 |
hello,
I'm studying the water flow around a cylinder (diameter 4 cm) located at the center o f a square basin (0.4m high 0.5m width 4 m length)and inlet velocity along x is 1.6 m/s. I'm wondering about the right way to set up turbulence boundary inlet condition. indeed there are different choices :01_simple_junction.png
thanks |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
