addLayersControls in snappyHexMesh around cylinder |
January 4, 2023, 03:39 |
Abhijit
Rep Power: 5 |
I created 3d mesh using snappyHexMesh for vortex-induced vibration of cylinder in OpenFOAM-v1906. When adding layers around the cylinder, the points are not distributed evenly around the cylinder. It created some unwanted vorticity in front of the cylinder. Many many thanks for the help.
I attached the mesh around the cylinder and vorticity contour. mesh.jpg vorticity.jpg This is my snappyHexMeshDict file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers true; geometry { cylinder1.stl { type triSurfaceMesh; name cylinder1; } refinementcyl { type searchableCylinder; point1 (0 0 -9.6); point2 (0 0 0); radius 0.7; } refinementBox1 { type box; min (0 -1 -9.6); max (2 1 0); } refinementBox2 { type box; min (2 -2 -9.6); max (6 2 0); } refinementBox3 { type box; min (6 -3 -9.6); max (10 3 0); } refinementBox4 { type box; min (10 -4.5 -9.6); max (20 4.5 0); } refinementBox5 { type box; min (-10 -10 -9.6); max (20 10 0); } }; castellatedMeshControls { maxLocalCells 100000; maxGlobalCells 2000000; minRefinementCells 0; maxLoadUnbalance 0.1; nCellsBetweenLevels 5; features ( { file "cylinder1.eMesh"; level 4; } ); refinementSurfaces { cylinder1 { level (5 5); // (surface refinement level, curvature refinement level) } patchInfo { type wall; inGroups (wall); } } resolveFeatureAngle 30; planarAngle 30; refinementRegions { refinementcyl { mode inside; levels ((1E15 5)); } refinementBox1 { mode inside; levels ((1E15 4)); } refinementBox2 { mode inside; levels ((1E15 4)); } refinementBox3 { mode inside; levels ((1E15 3)); } refinementBox4 { mode inside; levels ((1E15 2)); } refinementBox5 { mode inside; levels ((1E15 0)); levelIncrement (0 4 (0 0 1)); } } locationInMesh (1.001 2.001 -4.5001); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 3; tolerance 2.0; nSolveIter 300; nRelaxIter 5; nFeatureSnapIter 2; implicitFeatureSnap true; explicitFeatureSnap false; multiRegionFeatureSnap true; } addLayersControls { expansionRatio 1.15; finalLayerThickness 1.0; minThickness 0.002; relativeSizes true; layers { cylinder1 { nSurfaceLayers 21; }/* back { nSurfaceLayers 4; }*/ } nGrow 0; featureAngle 60; maxFaceThicknessRatio 0.5; nSmoothSurfaceNormals 10; nSmoothThickness 10; //minMedialAxisAngle 90; minMedianAxisAngle 90; nSmoothDisplacement 90; maxThicknessToMedialRatio 0.3; nSmoothNormals 15; slipFeatureAngle 30; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; meshShrinker displacementMotionSolver; solver displacementLaplacian; displacementLaplacianCoeffs { diffusivity quadratic inverseDistance 1(cylinder1); } } meshQualityControls { #include "meshQualityDict" relaxed { maxNonOrtho 75; } // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } mergeTolerance 1e-6; // ************************************************** *********************** // |
January 4, 2023, 10:17 |
Lucky
Rep Power: 66 |
From the image it looks like snappy is working exactly as it should. If the cells are not evenly distributed to your like, then the cells in the input mesh are not even.
January 4, 2023, 23:35 |
Abhijit
Rep Power: 5 |
Thank you very much for your reply. What do you mean by "cells in the input mesh are not even"? The nodes on the cylinder surface are not equally spaced and there is sudden jump in the element size along the surface of the cylinder. How do I rectify it?
January 5, 2023, 01:11 |
M
Rep Power: 12 |
The input mesh for snappyHexMesh is the blockMesh. Lucky suggests to check the spacing there. You can deactivate the layer generation and try to get the distribution as good as possible with a given blockMesh. Then go and reactivate layers generation.
[snappyHexMesh] snappyHexMesh - cylinder appears as a square! | chia87 | OpenFOAM Meshing & Mesh Conversion | 1 | October 23, 2018 21:41 |
[snappyHexMesh] Openfoam snappyhexmesh addLayersControls - non uniform layer | BakedAlmonds | OpenFOAM Meshing & Mesh Conversion | 1 | July 19, 2016 14:39 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
[ANSYS Meshing] uniform mesh, cylinder with a cut | Matiasi | ANSYS Meshing & Geometry | 5 | June 8, 2015 15:08 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
