January 9, 2023, 14:06 |
Artificial wall error in fluent
naji
Rep Power: 3 |
Artificial walls on 229 faces (36.5% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary.
**** 9* 6.7452e-02* 4.2456e-04* 1.2403e-04* 1.2762e-04* 0:03:18** 91 Artificial walls on 263 faces (44.8% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 10* 9.5896e-02* 1.4357e-03* 3.3114e-03* 8.5947e-04* 0:03:13** 90 Artificial walls on 168 faces (34.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 11* 1.2081e-01* 5.1255e-04* 7.1303e-04* 3.9098e-04* 0:02:50** 89 Artificial walls on 103 faces (25.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. * iter* continuity* x-velocity* y-velocity* z-velocity**** time/iter *** 12* 1.2865e-01* 3.0504e-04* 2.6108e-04* 1.7781e-04* 0:03:25** 88 Artificial walls on 114 faces (28.9% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 13* 1.0822e-01* 1.0121e-03* 1.3175e-03* 7.9926e-04* 0:03:00** 87 Artificial walls on 110 faces (28.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 14* 1.0300e-01* 2.7773e-04* 2.9792e-04* 2.0749e-04* 0:02:39** 86 Artificial walls on 50 faces (14.3% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 15* 8.5155e-02* 1.8876e-04* 1.5196e-04* 1.0855e-04* 0:02:23** 85 Artificial walls on 25 faces (9.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 16* 6.1318e-02* 6.8839e-05* 5.7725e-05* 4.4197e-05* 0:02:27** 84 Artificial walls on 8 faces (2.9% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 17* 3.7380e-02* 3.2700e-05* 2.6389e-05* 2.1119e-05* 0:02:13** 83 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 18* 2.2049e-02* 2.4332e-05* 1.4467e-05* 1.3157e-05* 0:02:01** 82 Artificial walls on 2 faces (0.5% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 19* 1.2633e-02* 1.3254e-05* 8.0841e-06* 7.6096e-06* 0:01:52** 81 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 20* 7.5741e-03* 8.7439e-06* 4.9641e-06* 4.5517e-06* 0:02:00** 80 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 21* 5.0388e-03* 6.9260e-06* 3.2612e-06* 3.0596e-06* 0:02:07** 79 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 22* 3.4927e-03* 5.2877e-06* 2.1201e-06* 2.0333e-06* 0:02:11** 78 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. * iter* continuity* x-velocity* y-velocity* z-velocity**** time/iter *** 23* 2.5274e-03* 4.0967e-06* 1.4290e-06* 1.4001e-06* 0:01:59** 77 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 24* 1.8612e-03* 3.1569e-06* 1.0064e-06* 1.0060e-06* 0:02:04** 76 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 25* 1.4336e-03* 3.0139e-06* 8.3737e-07* 8.4373e-07* 0:02:08** 75 Artificial walls on 2 faces (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 26* 1.0739e-03* 2.2359e-06* 6.0060e-07* 5.9933e-07* 0:01:56** 74 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 27* 7.8891e-04* 1.7429e-06* 4.4684e-07* 4.4735e-07* 0:01:46** 73 !** 27 solution is converged Flow time = 0.005s, time step = 1 Deleting Client...done Shutting down Server...doneArtificial walls on 229 faces (36.5% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. **** 9* 6.7452e-02* 4.2456e-04* 1.2403e-04* 1.2762e-04* 0:03:18** 91 Artificial walls on 263 faces (44.8% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 10* 9.5896e-02* 1.4357e-03* 3.3114e-03* 8.5947e-04* 0:03:13** 90 Artificial walls on 168 faces (34.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 11* 1.2081e-01* 5.1255e-04* 7.1303e-04* 3.9098e-04* 0:02:50** 89 Artificial walls on 103 faces (25.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. * iter* continuity* x-velocity* y-velocity* z-velocity**** time/iter *** 12* 1.2865e-01* 3.0504e-04* 2.6108e-04* 1.7781e-04* 0:03:25** 88 Artificial walls on 114 faces (28.9% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 13* 1.0822e-01* 1.0121e-03* 1.3175e-03* 7.9926e-04* 0:03:00** 87 Artificial walls on 110 faces (28.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 14* 1.0300e-01* 2.7773e-04* 2.9792e-04* 2.0749e-04* 0:02:39** 86 Artificial walls on 50 faces (14.3% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 15* 8.5155e-02* 1.8876e-04* 1.5196e-04* 1.0855e-04* 0:02:23** 85 Artificial walls on 25 faces (9.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 16* 6.1318e-02* 6.8839e-05* 5.7725e-05* 4.4197e-05* 0:02:27** 84 Artificial walls on 8 faces (2.9% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 17* 3.7380e-02* 3.2700e-05* 2.6389e-05* 2.1119e-05* 0:02:13** 83 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 18* 2.2049e-02* 2.4332e-05* 1.4467e-05* 1.3157e-05* 0:02:01** 82 Artificial walls on 2 faces (0.5% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 19* 1.2633e-02* 1.3254e-05* 8.0841e-06* 7.6096e-06* 0:01:52** 81 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 20* 7.5741e-03* 8.7439e-06* 4.9641e-06* 4.5517e-06* 0:02:00** 80 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 21* 5.0388e-03* 6.9260e-06* 3.2612e-06* 3.0596e-06* 0:02:07** 79 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 22* 3.4927e-03* 5.2877e-06* 2.1201e-06* 2.0333e-06* 0:02:11** 78 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. * iter* continuity* x-velocity* y-velocity* z-velocity**** time/iter *** 23* 2.5274e-03* 4.0967e-06* 1.4290e-06* 1.4001e-06* 0:01:59** 77 Artificial walls on 5 faces (0.4% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 24* 1.8612e-03* 3.1569e-06* 1.0064e-06* 1.0060e-06* 0:02:04** 76 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 25* 1.4336e-03* 3.0139e-06* 8.3737e-07* 8.4373e-07* 0:02:08** 75 Artificial walls on 2 faces (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 26* 1.0739e-03* 2.2359e-06* 6.0060e-07* 5.9933e-07* 0:01:56** 74 Artificial walls on 1 face (0.1% area) of pressure-outlet 8 to prevent fluid from flowing into the boundary. *** 27* 7.8891e-04* 1.7429e-06* 4.4684e-07* 4.4735e-07* 0:01:46** 73 !** 27 solution is converged Flow time = 0.005s, time step = 1 Deleting Client...done _________ Does anyone know about this error in fluent? I'm working on a fsi solution this error is written in the fluent console and then I got fluid flow threw an error in coupling window |
[snappyHexMesh] How to draw a 3D-Drawing for Meshing | Kahnbein.Kai | OpenFOAM Meshing & Mesh Conversion | 4 | June 15, 2021 12:16 |
Wall Motion in Fluent | suktan | FLUENT | 1 | May 31, 2021 23:51 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Wall function problem in Fluent | mefpz | FLUENT | 1 | October 10, 2007 13:43 |
