LBM(Lattice Boltzmann Method) force
Old   January 19, 2023, 01:07
Smile LBM(Lattice Boltzmann Method) force
HOJUN YU
hobing is on a distinguished road
Hi all,
I'm studying about LBM, so I have a few questions while studying, So I'm asking here It could be a simple software problem.
I know that if LBM is used, flow analysis is performed with a stochastic distribution of particles. But since it is a particle, how can I calculate the hydrodynamic forces such as drag and lift?
Instead of multiplying the pressure change in contact with the wall by the speed, I'm talking about when there is no wall. Here, the absence of a wall means that the wall was treated as a boundary condition, but the wall does not exist in the post-processing process. However, the particles recognize the location as a wall and bounce back. It's a form
I have tried
export block and block data (pressure * nomal Velocity) in using PARAVIEW : but In my case, there are no blocks, only point data.
Can someone help!
thank you!
hobing is offline   Reply With Quote
cfd, drag forces, fluid dynamics, lbm
particle-fluid interaction forces: Is Bouyancy body force or coupled force? atul1018 Main CFD Forum 1 April 28, 2022 08:53
Open Source Code for Lattice Boltzmann Method Halim Main CFD Forum 34 November 14, 2019 01:27
Initialize Pressure Field in Lattice Boltzmann Method with pressure-based equilibrium julia.p Main CFD Forum 1 November 13, 2017 18:49
Lattice Boltzmann Method - Forcing term sgunasekaran Main CFD Forum 1 April 26, 2017 08:02
Lattice Boltzmann method for multiphase flow? manxu Main CFD Forum 4 December 4, 2013 13:56
