Transient analysis
Old   August 9, 2000, 02:01
Default Transient analysis
denny
Hi, I will to know temperature and velocity distribution in room. I use Ansys5.4 How to define time step on that case.
How to modeling porous media on Ansys5.4
Thanks,
Denny
Old   August 9, 2000, 03:42
Default Re: Transient analysis
Istadi
Hi Friend,
Please to describe clearly the problem or the system to be adjusted. I think, you can generate the model about heat and mass transfer in your system, and the momentum equations. After that, you must solve the equations generated by the solver, or you can make the source code yourself by Fortran 90 Code or Matlab. It is easy to analyze the problem by the source program that developed. Thanks
Old   August 9, 2000, 05:45
mehdi ben elhadj
In order to know temperature and velocity distribution in room,you must generate the model (heat and mass transfer + equations)and make the source code, it's so easy. you can contact me of you have problems
Old   August 10, 2000, 17:11
clifford bradford
i don't think ANSYS Flotran (I assume you're usiing Flotran) allows for unsteady simulations for fluids
Old   August 11, 2000, 22:43
Istadi
Hi I agree to the Mr. Mehdi's comment. It is easy to solved by developing the heat, mass and momentum transfer, then generate the source code to compute it. After that, you validate your model parameters by the experimental data, and then you can simulate it for the other variables. Thanks
2-D airfoil transient analysis mike FLUENT 1 July 15, 2017 04:33
FSI Transient Thermal Analysis Abduri CFX 1 January 1, 2017 22:54
Transient Thermal Analysis in Ansys Workbench khurram1 ANSYS 0 November 22, 2010 02:40
Transient Analysis tutorial Bharatkumar FLUENT 0 June 4, 2010 08:25
transient analysis of silencer using cfx. mehul CFX 0 October 16, 2005 04:48
