2-D Flotran Problem
Old   August 18, 2000, 11:26
Default 2-D Flotran Problem
Mark Osterbrink
I'm trying to do a 2-D flow tran analysis of an airfoil close to the ground. The solution goes along fine, then the pressure starts to oscillate and it blows up. Any ideas as to what I can do to fix it? The boundary conditions are fixed velocities at all boundaries. Any ideas?
Old   August 18, 2000, 22:13
Default Re: 2-D Flotran Problem
John C. Chien
(1). Have you asked the vendor's support engineer why this is happening? (2). About 10 years ago, I have written a 2-D Navier-Stokes code to compute flow over a car above the ground. Both flow over and under the car(2-D) were computed. It converged in about 10 min. on a PC/486. (3). So, it is likely that the problem is between you and the code and the vendor. agree? (4). Ask the support engineer to show you how to do it right.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
I have a Problem with Flotran Ashok CFX 1 June 16, 2004 20:55
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
