checkMesh - Foam Fatal IO Error - newbi
Like Tree1Likes
  • 1 Post By LuckyTran
Old   May 16, 2023, 12:20
Default checkMesh - Foam Fatal IO Error - newbi
Luis Quezada
L_Qu3z4da is on a distinguished road
Hi, sorry for bother you. I am newbi
I cannot run checkMesh command. Yesterday I was running it on system folder and when researching I learned that commands must be done on top folder, I tried again but got
--> FOAM FATAL IO ERROR: (openfoam-2206)
Entry 'format' not found in dictionary ""
I am following Tobias Holzmann smoking pipe tutorial
L_Qu3z4da is offline   Reply With Quote
Old   May 16, 2023, 16:25
Lucky
You should run (almost) all commands from the top level dir, in this example that would be SmokingPipefoam. Although you can run some commands like checkMesh from within the constants folder.
Make sure your controlDict is in SmokingPipefoam/system and is not buried in more subdirectories. Make sure it is a valid controlDict. In this example, it looks like your control dict or another dict is missing the OpenFOAM header if it can even find your controlDict at all. The header is absolutely necessary because foam needs to know that it is reading ascii text and not other coded formats.
 |  \\    /   O peration     | Version:  plus                                  |
 |   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
 FoamFile
     version #.#;
     format      ascii;
     class       dictionary;
     location    "system";
     object      controlDict;
Old   May 16, 2023, 17:42
Default There is controlDict
Luis Quezada
There is a controlDict. I copied it from motorbike tutorial. At this point I am kind of desesperate, I dont know C++ and most of the times I cannot interprete what those warnings are telling me I am only sure that I did the same as the videos and I cannot do neither checkMesh nor snappyHexMesh and stupidly enough I need OF for my bachelors thesis tuition and I cannot advance. CAD tutorial model was horrible so I made other with sourfaces in order to follow the tutorial but I cannot simply continue. I really would appreciat it if you give it a look.
https://1drv.ms/u/s!AgN4cFrYS98LkxCo...PY4H8?e=BpOwmn
Old   May 16, 2023, 20:20
Lucky
The error is saying this line is missing from one of your dicts
format      ascii;
L_Qu3z4da likes this.
openfaom, pre processing
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 07:53
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
