UDF velocity inlet
Old   June 10, 2023, 13:23
Default UDF velocity inlet
hassan-1504 is on a distinguished road
Hello everyone,
i have little problem, i have created an UDF File, for velocity inlet, in a tube but when i plot it with report definition, i dont get a sinusoid, i want to know what is the problem, i have define correctly UDF file in user define fonction, but the plot and values obtained aren't correct.
Thank you for your help
File Type: c udf velocity.c (231 Bytes, 5 views)
hassan-1504 is offline   Reply With Quote
Old   June 14, 2023, 07:38
Prasant
PKP_India is on a distinguished road
The profile UDF looks fine. if there is any compilation issue, please check for errors.
if there is no compilation issue Please see below:
1. since your velocity profile is dependent on time, if you plot at the beginning it will give Uinlet=30. but as the time gets updated, you will see a nice sine profile curve at your velocity inlet.
PKP_India is offline   Reply With Quote
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 11:19
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 06:43
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 14:19
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 09:44
