Interface detection criteria in Euler-Euler multiphase flow |
September 29, 2023, 02:56 |
Krishna
Rep Power: 9 |
Hello Everyone,
Can anyone tell me what condition can we used as an interface detection criteria in multiphase Euler-Euler simulation (with Modified-HRIC scheme). My case is gas-liquid mass transfer in cylindrical bubble column: Dimension- (D, H)= (150, 460) Bath depth (filled with water)=250mm Free board filled with air=210mm At the free surface there are diffused cells. For example, in cells above 250mm, volume fraction of liquid is detected due to diffuse characteristic of Euler-Euler model, although, I have used sharp/diffuse interface capturing scheme. So I guess volume fraction can not be used as a criteria to detect the interface. Can anyone guide me with this? any reference will be appreciated Regards Krishna |
euler-euler, interface detection, mass tranfer, multiphase |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
