Multyphase air and water drag forces
Old   January 9, 2024, 00:24
Default Multyphase air and water drag forces
Kil
Kil's Avatar
Serge
Kil is on a distinguished road
Dear forum members, tell me please, for a test example such as the openfoam DTCHull tutorial in the forces.dat file, are the values of viscous forces and pressure forces are given only for the water phase or for two phases at once (water + air)?
If the results are given for two phases, how can we get separate solutions for the air and water phases?
if the result is only for the water phase, how do I add a solution for the air phase?
Kil is offline   Reply With Quote
air and water drag forces, multyphase flow
MultiphaseEulerFoam in OpenFOAMv9 - problems with small particles flowgeek OpenFOAM Running, Solving & CFD 5 January 19, 2022 07:00
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 13:36
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
Coefficient of Drag for Air and Water kilroy Main CFD Forum 3 January 29, 2014 14:35
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
