January 9, 2024, 00:24 |
Multyphase air and water drag forces
Serge
Rep Power: 6 |
Dear forum members, tell me please, for a test example such as the openfoam DTCHull tutorial in the forces.dat file, are the values of viscous forces and pressure forces are given only for the water phase or for two phases at once (water + air)?
If the results are given for two phases, how can we get separate solutions for the air and water phases? if the result is only for the water phase, how do I add a solution for the air phase? |
air and water drag forces, multyphase flow |
MultiphaseEulerFoam in OpenFOAMv9 - problems with small particles | flowgeek | OpenFOAM Running, Solving & CFD | 5 | January 19, 2022 07:00 |
How to use a UDF to set the volume fraction in the cells next to a wall? | DF15 | Fluent UDF and Scheme Programming | 33 | August 20, 2020 13:36 |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 19:24 |
Coefficient of Drag for Air and Water | kilroy | Main CFD Forum | 3 | January 29, 2014 14:35 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
