November 22, 2023, 06:50 |
OpenFOAM new version problems
jim rainy
I have been simulating flow over an in line oscillating cylinder and control rod system in the lock in region. I started the simulations on OpenFOAM - 10 version in January of 2022, in a PC that had Windows software. Then, after finishing my thesis, I had to re-run the simulation on a broader spectrum of frequencies, on a cluster that had Ubuntu software. I had to install the newer version of OpenFOAM, OpenFOAM - 11, that has revised solvers and dynamic meshes. Every parameter of the simulation remaint the same, the only thing that changed is the dynamicMeshDict that had to recomposed in a different fashion. Also, I ran pimpleFoam on OpenFOAM 10 and on OpenFOAM 11, i have to change controlDict with foamRun and incompressibleFluid application, that reads pimple from fvSolution (is it the same thing?). The results I am getting for the same frequencies and the same in line oscillations (I am running laplacian Displacement), differ! What is happening? The mathematical models and everything is the same! P.S. I am running the simulations in parallel, 4 processors, scotch decomposing Thank you in advance, I really need your help. |
OpenFOAM version switch from ESI to Foundation | vronti | OpenFOAM | 1 | May 2, 2022 03:48 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Simulation DNS for two phase flow in openFoam | ht2017 | OpenFOAM Running, Solving & CFD | 0 | December 8, 2020 05:50 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Gmsh] gmshToFoam on openfoam windows version of OpenFOAM v1812? | SihunLee | OpenFOAM Meshing & Mesh Conversion | 0 | June 17, 2019 05:44 |
