NSEs with Incompressible Ideal gas as buoyancy term
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By FMDenaro
Old   November 26, 2023, 17:03
Default NSEs with Incompressible Ideal gas as buoyancy term
Memet1c is on a distinguished road
Hi all,
I would like to know if the following formulation is correct.
I am trying to express the NSEs in conservative form using the incompressible ideal gas model as the buoyancy term.
Incompressible ideal gas assumes:
\rho = \frac{p_{op}}{RT}
Where the density only varies with temperature and not pressure.
The NSEs expressed in conservative form:
\partial_{t}(\rho) + \partial_{x_{i}}(\rho u_{i}) = 0 - Continuity
\partial_{t}(\rho u_{i}) + \partial_{x_{j}}(\rho u_{i}u_{j}) = -\partial_{x_{i}}(p) + \mu \partial_{x_{k}x_{k}}(u_{i}) + \rho g_{i} - Momentum
c_{p}[ \partial_{t}(\rho T) + \partial_{x_{i}}(\rho u_{i} T)]= \kappa \partial_{x_{i}x_{i}}(T) + \dot{q} - Energy
Note that the viscous dissipation and pressure work terms have been omitted from the energy equation.
My question from here is, how do I proceed to solve this system of equations numerically?
Given that I have expressed the density as a function of purely temperature, do I substitute it into my continuity, momentum, and energy equations? Or do I solve my system of equations separately from my equation of state, only updating the density field after marching forward in time.
Any literature recommendations explaining the incompressible ideal gas model in detail, and especially its numerical implementation would be greatly appreciated.
Memet1c is offline   Reply With Quote
Old   November 27, 2023, 17:37
Lucky
You certainly can substitute the equation of state directly and eliminate density if this is the only CFD you will ever do.
General purpose solvers will use various approaches because they want their code to solve many different types of problems, i.e. they want the same code to be easily switchable from incompressible idea gas to classical ideal gas with just the push of a button.
arjun likes this.
Old   November 27, 2023, 17:50
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Memet1c View Post
Hi all,
Do you have some specific reason for that formulation? For small temperature variation, the Bousinnesq model works fine.
Otherwise have a look to the low Mach formulations.
FMDenaro is offline   Reply With Quote
Old   November 27, 2023, 19:56
The code available to me uses the Boussinesq model, but the temperature range I encounter in my scenario is very large. From what I understand, Boussinesq assumes the density variation due to temperature is small, and thus approximately linear. This is not the case for me.
I chose to use the incompressible ideal gas model instead, as the pressure variation in my problem is very small.
Old   November 27, 2023, 20:03
Lucky
I am confused why you are asking how to numerically solve something if you already have a working code. What even is the question? I can't validate the performance of your code for you.
Old   November 27, 2023, 20:05
Apart from the versatility of being able to switch between models, what are other benefits with applying the EOS separately from the NSEs? Is the implementation in the main solving loop more straightforward?
Also, are there any additional modelling errors as opposed to substituting the EOS directly?
Thanks,
Old   November 27, 2023, 20:09
The current code I have is purely incompressible, density is constant. I am not sure if I can include density as a field straight away, especially during the step which solves for pressure as a Poisson equation. I am still looking into this.
Old   November 27, 2023, 20:30
Lucky
What you have is constrained coupled system of equations. You have your transport equations plus the EOS (the constraint).
When you hard-code the constraint into the transport equation you also force the errors/correctors to be forcibly propagated. When these correctors are large, they can cause the problem to diverge. A similar issue also occurs in the pressure-velocity coupling problem when you solve a Poisson problem for pressure. Not propagating them can mean you need more sweeps to converge (until the correctors are propagated throughout the domain). There is always a tradeoff between stability and convergence rate. Hence, there are endless permutations of solvers available.
For example, sometimes you start cranking and end up with a negative temperature, now you have a negative density and you're screwed.
Old   November 27, 2023, 21:02
I will have to look further into this.
Thanks for your advice
Old   November 28, 2023, 04:40
Starting from your code, it is suitable to use the low Mach formulation. That is largely used for combustion problems. This way you take into account larghe temperature gradient.
Memet1c likes this.
Old   November 29, 2023, 08:54
Matthew
hunt_mat is on a distinguished road
Hi all,
I think you may need to use Dalton's law of partial pressure to formulate a multiple component fluid, one which is a viscous fluid and the other is an incompressible gas.
hunt_mat is offline   Reply With Quote
Old   November 29, 2023, 16:42
Sorry I'm confused, why would the incompressible fluid be inviscid? And how exactly does this help?
Old   November 29, 2023, 17:18
Matthew
I never said anything about inviscid.
Old   November 29, 2023, 18:08
Sorry, I thought by specifically describing one of the fluids as viscous the other would not be so (I guess both fluids are viscous then?). In any case, my working fluid is air, I don't see how breaking it down to its constituents helps me here.
My scenario is boundary layer flow over a flat surface, with temperature dependent heat release. I am not simulating combustion with species transport.
Old   December 1, 2023, 05:43
Matthew
So your heat source is a z=0(say), and you want to understand the heat induced flow in an incompressible gas?
Old   December 2, 2023, 10:31
Correct. If I could, I would simply use the Boussinesq approximation with the incompressible NS, but my temperature range is very large. I can expect a deltaT of the order of 1000 K
buoyancy, convection, ideal gas, temperature and density
How does Fluent calculate the specific enthalpy for incomp. ideal gas? brunolago FLUENT 0 October 7, 2022 07:08
Incompressible ideal gas Nadaaaa22 FLUENT 5 September 8, 2019 21:27
Energy equation - Incompressible Ideal Gas? Wingman ANSYS 3 April 9, 2017 01:49
difference between ideal gas and incompressible? Ric Main CFD Forum 1 March 24, 2007 13:07
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
