Thermal stress tensor in fluids
Old   November 29, 2023, 09:30
Default Thermal stress tensor in fluids
Matthew
hunt_mat is on a distinguished road
I am looking at a compressible viscous fluid that compresses under heat applied to it around the edges. I know what the thermal stress tensor for an elastic material, but things are different for a viscous fluid. Does anyone know the correct mathematical equation for a viscous fluid?
hunt_mat is offline   Reply With Quote
Old   November 29, 2023, 09:55
Lucky
As long as we are talking about thermodynamic equilibrium and not going into the statistical thermodynamics or QED then the usual compressible navier stokes is sufficient (it's already compressible)
Old   November 29, 2023, 09:58
Matthew
Unfortunately, it isn't. I have my material in an oven and its compressibility is determined by the heat is coming from an oven. So unfortunately that doesn't apply here. I need to add it in.
Old   November 29, 2023, 10:03
Lucky
Compressibility is already taken care of by the EOS.
For gases anyway, the only thing you can do better is to use the real gas law instead of ideal gas law which has the isothermal/volumetric compressibility in it. Note that the ideal gas model constrains the isothermal compressibility
Where it typically breaks down is for non-newtonian behavior because you are heating a slurry and not a gas but I doubt that is your question.
Old   November 29, 2023, 10:04
Matthew
Only thing you can do better is to use the real gas law instead of ideal gas law which has the isothermal/volumetric compressibility in it. Note that the ideal gas model constrains the isothermal compressibility
So you don't know. I know what the continuity equation is. That's not what I'm asking.
Old   November 29, 2023, 10:06
Lucky
I get what you're asking, what is the stress tensor look like for a jello
So can you say what is your substance?
My point is you are just looking for a constitutive relation for your specific substance, which is usually trade information, and it's not really a theoretical problem.
Old   November 29, 2023, 10:52
Matthew
I'll use use the isotropic thermal stress tensor: \mathbf{T}=\beta(T_{a}-T)\mathbf{I} and hopefully that will give me what I need.
Old   November 29, 2023, 11:18
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Not sure what you want, in fluid dynamics we have a foundation about the fact that the stress tensor and the velocity gradient are linked by means of the Newtonian model.
Thus, temperature acts in the stress tensor by means of the two viscosity coefficients but, in general, the Stokes hypothesis reduces to only the viscosity function mu(T) and a functional relation like Sutherland is used.
However, the disregarded contribution to the tensor appears like mu2*(Div v)I
FMDenaro is offline   Reply With Quote
Thermal stress analysis with heat flux boundary condition cvasse OpenFOAM Running, Solving & CFD 0 March 20, 2018 09:46
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
[stressAnalysis] How to simulate thermal stress and heat transfer simultaneously using OF? masb OpenFOAM CC Toolkits for Fluid-Structure Interaction 18 July 20, 2015 22:24
tube heat ex-changer involving two fluids separated by thermal baffles Ya_Squall2010 OpenFOAM Running, Solving & CFD 5 January 31, 2015 03:46
CAN i calculate thermal stress in CFX??? prayskyer CFX 3 July 5, 2006 20:05
