December 9, 2023, 09:02 |
Question on steady and unsteady simulation
Rep Power: 6 |
Recently, I came across a fundamental question about steady and unsteady simulation, but I am unable to figure it out. Looking forward to some experts:
It's very common to use a steady flow simulation to initialize the unsteady flow simulation; however, now that the flow is already stable, what is the cause of the unsteadiness when switching to the unsteady simulation? For example, I did a simulation on the 2D laminar flow vortex shedding by Star-CCM+ (a tutorial case): 1) When I start from unsteady simulation directly, the shedding pattern occurs as expected; (see figure1) 2) If I start the flow by steady simulation, and then switch to the unsteady simulation, the flow pattern is still identical to the steady state, Nothing Changed (see figure 2), residuals are very low and Cl is a line during the entire simulation (see figure 3&4). And seems that continuing the simulation won't get the shedding pattern as before. I am very curious about the rationale behind these phenomena. Thank you! |
December 9, 2023, 12:48 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
In case of a low Reynolds number, the flow is steady by its nature, no matter of steady or unsteady simulation. The difference is that the steady simulation resolve only the final state while in the unsteady simulation, depending on the initial and BCs, you can simulate the physical transient condition developing in the steady solution. If the Reynolds number exceeds the value for a physical steady state, the steady simulation simply must not converge. If it does, then the numerical diffusion changes the Re number to a physical lower value. |
December 9, 2023, 13:59 |
#3 | |
Sayan Bhattacharjee
Rep Power: 8 |
Your flow seems laminar. The steady state solution that you're showing has converged (as seen by the drop in residuals, and then becoming flat). Depending on how your steady state solver is configured, it could've used local timestepping to get the final result. This won't show any vortex shedding. While the transient simulation shows vortex shedding because it solves each intermediate timestep until reaching the final steady state. Meaning ... if the initial and boundary conditions would create vortex shedding, then they will show up in the simulation, and at the end become as same as the steady simulation's result. i.e both are correct. However, Switching to transient after initializing with steady state does nothing, because the flow is already converged to what you'd expect for this low Re flow. |
December 9, 2023, 20:41 |
Lucky
Rep Power: 66 |
The residual plot doesn't really look right to me for the unsteady portion. Is this done with a super large time-step or high Courant number? It's possible but uncommon that the steady solution is so perfect that the unsteady calculation stays perfectly stationary (assuming the transient calculation is being done correctly).
December 11, 2023, 08:13 |
Beyond what others suggest, I second LuckyTran answer.
More specifically, the initial conditions of the two unsteady simulations (the one starting from steady condition and the one starting from scratch) are not the same and the specific condition you are simulating is possibly not completely unstable (including the effect of numerics). It is then very possible that when starting from the converged steady simulation, the flow conditions are not enough unstable and any disturbance not strong enough to lead to unsteadiness. In contrast, your scratch initial conditions are probably too far from equilibrium and large distrurbances are introduced during their adaptation, large enough to not be damped by the flow conditions. |
December 11, 2023, 08:16 |
Rep Power: 6 |
It's a simple laminar flow. The boundary conditions are the same for steady and unsteady simulations, and there should be vortex shedding at this Re state, as StarCCM+ tutorial shown.
I also want to know the cause of the unsteadiness in other "usual" steady simulations. Is it because the mesh is so fine to capture the small separation that shows the unsteadiness? |
December 11, 2023, 09:48 |
#7 | |
Rep Power: 71 |
December 11, 2023, 12:29 |
#8 | |
andy
Rep Power: 18 |
Have you checked if the flow field has changed by a tiny amount from the steady one after a few pass throughs? The residuals won't show anything you will have to look at some field value down to the last few places of precision. What are the properties of the numerical scheme w.r.t. preserving energy? If it is dissipating the energy in the initial tiny long motions that need to form before anything larger can get going then this will lead to the steady solution remaining. If the transient scheme is closely related to the steady state one this is reasonably likely. I would be careful about assuming laminar flows to be simple because they are still nonlinear. They can have multiple solutions, asymmetric solutions with symmetric boundary conditions, instabilities and more. |
December 11, 2023, 13:03 |
#9 | |
Rep Power: 71 |
I agree and since the energy would transfer from small scale perturbation to larger scales, that is an inverse energy transfer that the artefact of the numerical method must not suppress. A quantitative method is to plot the max time derivative in time and wait to see if it starts increasing. |
December 12, 2023, 07:10 |
#10 |
Rep Power: 6 |
The information is shown in the figure attached below.
December 12, 2023, 07:15 |
#11 | |
Rep Power: 6 |
The numerical scheme is coupled algorithm with second order discretization. |
December 12, 2023, 07:25 |
#12 |
Rep Power: 71 |
What about the numerical discretization ? The Re number is low, just the numerical diffusion can suppress the oscillations (real Re number <50) or it requires several turnover times to realize the fully developed field.
How long did you run the cose from the steady state ? |
December 12, 2023, 09:28 |
#13 | |
andy
Rep Power: 18 |
In an LES scheme arranging the differencing to numerically conserve mechanical energy is beneficial given it's role in turbulent motion. For a steady state scheme the opposite is the case with energy in the unsteady motion not wanting to be conserved but dissipated as quickly as possible to get to steady state. I am not familiar with the details of the commercial code you are using but there is a fair chance it has settings for alternative differencing schemes for different types of flows. With luck this will be in the manual with guidance on what is best for what. PS Have you checked if the solution has moved slightly away from steady state by looking at some field values and not the residuals or large integrated quantities which won't pick up tiny changes. Last edited by andy_; December 12, 2023 at 09:32. Reason: PS |
December 13, 2023, 07:49 |
#14 | |
Rep Power: 6 |
December 13, 2023, 07:58 |
#15 | |
Rep Power: 6 |
As for the field values, do you mean such as the local pressure of one point in the flow field? |
December 13, 2023, 08:01 |
#16 |
Rep Power: 71 |
December 13, 2023, 09:54 |
#17 | |
andy
Rep Power: 18 |
The scheme is likely to be consistent and so if it isn't initiating shedding (which we haven't yet fully checked) then increasing the grid resolution will lead to it eventually starting. Alternatively changing to a numerical scheme developed for LES will likely enable shedding to initiate on coarser grids. You need to check where instabilities are likely to start forming which will be a waviness in the boundary layer over the cylinder. I would check all solution variables in a few places and get the values printed out by the solver and not the plotting software which may be averaging and dropping precision. |
December 15, 2023, 07:41 |
#18 |
andy
Rep Power: 18 |
PS My assumption that a fine grid is all that is needed to get vortex shedding may not be correct. When flow patterns switch with some parameter like Reynolds number there can be a range of that parameter where one can get either flow pattern depending on the initial conditions. Whether this is the case here I am not sure but one can likely look it up if interested. This effect can be quite strong with swirling flows and caused me some bafflement 40 years ago with some of my early simulations.
December 18, 2023, 06:51 |
#19 |
Rep Power: 6 |
I did some tests on this case (same mesh and same time-step):
1. First steady simulation with coupled solver, then unsteady simulation with coupled solver, as shown no vortex shedding, and very low residuals; 2. First steady simulation with coupled solver, then unsteady simulation with segregated solver (SIMPLE algorithm), residuals rise gradually and vortex shedding happens in the end; 3. First steady simulation with segregated solver, then unsteady simulation with segregated solver: the steady state is very difficult to reach (high residuals, bad convergence), vortex shedding is shown even in steady simulation, and of course, there is vortex shedding in the unsteady simulation. It seems that the solver (coupled or segregated) is the main course, which is quite astonishing to me. Because from my side, these two solvers should provide close results. Coupled solver usually is more stable and needs less iteration than segregated solver, and coupled solver is widely used, even as the best practice in many industries. In my case, it looks like the "error" is the cause of the unsteadiness. SO weird... |
December 18, 2023, 06:55 |
#20 | |
steady and unsteady state |
Start the unsteady computation based on the steady simulation results | Amber0922 | SU2 | 2 | July 22, 2023 22:23 |
Using steady state results to initialize flow in unsteady simulation | sabesj_ | STAR-CCM+ | 3 | February 8, 2023 05:03 |
starting with steady simulation then implicit unsteady decreases convergence time? | hguvenc | Main CFD Forum | 3 | November 19, 2021 08:17 |
Unsteady simulation gives steady result | tundradot | Main CFD Forum | 3 | October 1, 2021 13:44 |
How do set a steady solution as an initial solution to an unsteady simulation? | pro_ | SU2 | 10 | April 28, 2020 17:05 |
