interFoam crashes after running 17s with exit code 3
Old   March 20, 2024, 10:42
Default interFoam crashes after running 17s with exit code 3
Shuvashish Roy
sroy is on a distinguished road
I am running a test pump station model, which crashes after running for a while. I have used volume flow rate both in the inlets and outlets. I tried using different mesh refinements and smaller time steps but couldn't figure out how to fix the problem. I am also attaching the checkMesh.out along with the model files. I have just found "If you specify velocity/flow rate at the inlet/outlet, you should specify pressure at the outlet/inlet." Is it possible to use pressure in the inlet and flow at the outlet? I highly appreciate your help.
You will find the model files at: https://dsllctn-my.sharepoint.com/:u...PguLA?e=IKxTqi
I have ran another model of the same pump intake station where I used pressureInletOutletVelocity for the inlets and flowRateOutletVelocity for the outlets. This model also crashed after running 17s with similar error message. Here is the link of the model files: https://dsllctn-my.sharepoint.com/:u...OZXRQfoCvznmDw
I highly appreciate with any insight. Thanks.
sroy is offline   Reply With Quote
interfoam solver, openfaom, pump boundary condition
interFoam ended prematurely and may have crashed. exit code 3 nguyenduclong777 OpenFOAM Running, Solving & CFD 1 March 19, 2024 15:13
mpirun issue: Exit code 144 J.Kim. OpenFOAM Running, Solving & CFD 0 April 5, 2023 01:58
Fortran->Assembly : How to remove redundant non-vectorized code? aerosayan Main CFD Forum 6 November 20, 2020 05:37
CFX Error Exit Code 2 ERROR #001100279 - Particle Tracks File Issue? AllyB2106 CFX 1 April 4, 2018 17:55
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 05:58
