WM_PROJECT_DIR: parameter not set or null. How to setup an environment for OpenFOAM? |
March 23, 2024, 20:23 |
Phillip Russo
I installed on Ubuntu Jammy Jellyfish (WSL2):
Distributor ID: Ubuntu Description: Ubuntu 22.04.4 LTS Release: 22.04 Codename: jammy from these instructions. After adding a repository: sudo apt-get install openfoam2312-default OK... So I have some examples: /usr/lib/openfoam/openfoam2312/tutorials/incompressible/pimpleFoam/LES/vortexShed ``` /usr/lib/openfoam/openfoam2312/tutorials/incompressible/pimpleFoam/LES/vortexShed$ sudo ./Allrun ./Allrun: 3: WM_PROJECT_DIR: parameter not set or null ``` I also ran "source bashrc" from the openfoam/etc folder. How can I get Allrun to run? |
[surface handling] Decomposing Faces after Extrude2DMesh with autoPatch | JEBland | OpenFOAM Meshing & Mesh Conversion | 5 | December 6, 2021 07:28 |
Using a Parameter Set with Fluent Meshing Workflow | ro_bb | FLUENT | 1 | July 18, 2019 05:06 |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
Unable to set home environment in gambit | Neel Naik | FLUENT | 3 | January 23, 2007 11:02 |
FATAL ERROR: "HOME" environment MUST be set ! | gamer | FLUENT | 0 | April 19, 2006 03:50 |
