Heat Flux and Heat Transfer Coefficient Repot Problem |
April 23, 2024, 00:46 |
Kevin
Rep Power: 2 |
Hello all,
I am having a problem calculating the heat transfer coefficient and boundary heat flux as a result. After setting up an expression report that was set to ${HeatTransferCoefficient}, I got the error "Cannot evaluate field function Heat Transfer Coefficient." Also something really weird is happening. I am able to get a value for a "surface average report of boundary heat flux on volume mesh" but I am not able to get the "surface integral of boundary heat flux on volume mesh." Furthermore, when trying to output the heat transfer coefficient, I get a "no dat, undefined ratio." What ratio is not defined? I am confused and need help from one of you experts. Thank you all! |
heat flux, heat flux coefficient, heat transfer, reports, star-ccm |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
