Shape function of P1isoP2/P2 triangle element |
October 7, 2000, 00:19 |
Dear All.
Could you recomend me a source (book or article) with detail of the shape function of P1isoP2/P2 triangle element that used in N3S software. Thanks |
October 7, 2000, 00:23 |
Re: Shape function of P1isoP2/P1 triangle element
Dear All,
Sorry, that should be P1isoP2/P1 triangle element Thanks |
October 8, 2000, 14:27 |
The report on N3S code is a good reference:
Chabard J.P., Projet N3S de mecanique des fluides, manuel theorique - version 2.0. HE-41/88.09. 1989 EDF. But these shape functions can be described very easily (from Burnett): On each triangle, The shape functions for P1 approximation are the following: uj(x,y)=(aj+bj*x+cj*y)/2Delta, j=1,2,3 aj=xk*yl-xl*yk bj=yk-yl cj=xl-xk delta=area on triangle and the subscripts j,k,l have the values 1,2,3 for u1 and are permuted cyclically for u2 and u3. Here, u can be any functions (velocity, pressure). For P1isoP2/P1, the pressure is interpolated on the big triangles. These triangles are splitted into four triangles and the velocity is interpolated on each of these triangles. |
October 8, 2000, 20:25 |
I see. Thank you very much!
Stream function from known velocity | Beginner | Main CFD Forum | 10 | September 26, 2018 12:49 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Could you please help me about the VTKFoam | liugx212 | OpenFOAM Pre-Processing | 5 | February 13, 2008 11:31 |
Shape Functions for Curved 2-D Triangular Element | Abhijit Tilak | Main CFD Forum | 0 | November 30, 2003 13:14 |
How solve the 2nd differential of shape function? | Yiling Lu | Main CFD Forum | 0 | July 20, 2002 09:17 |
