December 20, 2000, 06:37 |
Water flow into boat
Being a recreational fisherman, I have the following question. How much water would flow (gal per second) into a boat, if it had a 1" square hole in the bottom and the bottom is 18" under water? What I'm trying to do is to size bilge pump capacity. Could you provide the formula and constants that determine the results. Thank you in advance.
December 20, 2000, 09:25 |
Re: Water flow into boat
For small appertures :
Volume flow rate = Cd x A x sqrt(2 x g x H) Cd : discharge co-eff (about 0.6 for water through a sharp edged hole) A : hole area g : 9.8 ms-2 H : height of water |
December 20, 2000, 18:23 |
Rich, thanks for responding. I have question about the constant "g", what is it, what are the units? Thanks
Gus P |
January 2, 2001, 04:42 |
g is gravitational acceleration = 9.8 meters per secondsquared
Simple Water Tank Transient | 88phil88 | CFX | 5 | March 17, 2014 03:48 |
hot water flow into a lake/river | waters | OpenFOAM | 0 | January 21, 2011 09:49 |
Free - Surface Flow: Split Fluid Forces acting on a Boat Hull | eee | CFX | 2 | August 28, 2009 08:36 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
