January 5, 2001, 23:53 |
Rectangular Mesh
Does anyone know what sort of contour plots of streamfunction i can expect when my problem set involves flow in a rectangular mesh with insulated horizontal walls and vertical walls at hot and the other cold temperature? And also if the upper horizontal wall is a free surface?
January 8, 2001, 01:22 |
Re: Rectangular Mesh
If upper wall is a free surface, you will get "U" shape streamline contours, with the flow coming in along the cold wall and going out along the hot wall. If top wall is closed, you will get circulatory flow pattern. Correct me if I am wrong.
GS |
January 18, 2001, 00:03 |
I tried running my program, but the contour plot i got is something like a circulatory flow pattern. Think there is something wrong with my boundary conditions of temperature. Since the top is a free surface, should i still assume an adiabatic wall where heat flux is zero? Currently, my vorticity at the top wall is set as zero while the other walls are per normal. Initial streamfunction is set at 1.
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 09:13 |
mesh rectangular box with 0.1mm diameter holes in gambit | sohi | FLUENT | 0 | April 23, 2011 02:47 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
