November 12, 1998, 19:55 |
Gradient Matrix in FEM
At the moment I am developing a FEM code to solve the Navier Stokes equations splitting the equation in three. The equations are: one for convection, one for diffusion and one for pressure. In the pressure equation I am obtaining an anti-simetric matrix. I would like to know if someone has had such experience and any idea of where could be the bug. I really would be glad to have some sugestions......!
November 18, 1998, 19:25 |
Re: Gradient Matrix in FEM
Hello ThoLi,
I have tried working with two equations also: Burger's eq. for velocity and Poisson eq. for pressure, using the projection method (Chorin), and also I was using analitycal integration for the Galerkin integrals. Some strange things were hapenning, the solution started converging to a very good solution and instead of converging (small variations in velocity) it continued incrementing, diverging from the desired solution. * And so I did the splitting in three eqs., in a way that I could verify the evolution of each one, and I also used Gauss Quadrature to do the integration. The simetric matrices are OK, mass: Ni Nj and grad: dNi/dx dNj/dx, x = x, y, but the other ones become antissimetric, for example, the divergent: Ni dNj/dx, x = x,y, and the non-linear convective term has a similar problem: Ni dNj/dx Nk. * For example, if I have flow over a plate, it is ok, if I have flow in a duct, one side will be the opposite to the other. * If you could send me na example of a divergent matrix, it would be very usefull for me to find my error, because I haven't found this matrix in any literature or papers. * Thanking you very much for your interest and help, Sincerely yours, Astrid * P.S. *My equations: term1: viscosity (second order derivatives of velocity) - Equation 3 term2: convection (first order derivates) - Equation 1 term3: gradient of pressure Equation 2: two steps: grad(P) = div(v) / dt term4: divergence of velocity dv = - div(p) * dt |
November 23, 1998, 12:25 |
Hello Astrid,
please send me (or post) also the following informations: which finite elements do you use (shape: triangular/rectangular; linear,quadratic,... polynomials; integration gaussian (how many points?); ) What variables are involved? (v: velocity?; p: pressure? P: also pressure? t: time? are there more? ) How big is your Reynolds-number? Have you tried zero convection (= zero Reynolds)? Describe your time-discretization scheme! (What have you done with dv/dt? with div(v)/dt?) give me some sketches of your geometry! and of the flow directions, you expect! you can send me a fax at +49 89 - 63812-515 (it's a shared fax, so send also a page it's for me!) ------ I used: rectangles with bi-quadratic polynomials, i.e. x^2 * y^2 was included; integration with a four-point-gaussian in x- and y-direction (resulting in 16 = 4*4 points) v: velocity, (x,y) -> (vx,vy) ; p: pressure, (x,y) -> p (no time, no time-discretization) My Reynolds-Number was 20; I had an exact solution for the case Reynolds=0 and incremented the Reynolds-number (the influence of the convection) in small steps; I tried SIMPLE as solving algorithm, but then used a direct solver, because I didn't find the right parameters for SIMPLE to converge ... I'll send you a matrix, when I know your elements ... greetings ThoLi |
November 30, 1998, 20:09 |
Hello ThoLi, I am writting the formulation I've been using and as soon as it is ready I'll send it to you. Thank you for your interest, Astrid PS: can I send you a Word97 file? or would it be better to fax it?
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
OpenFOAM version 1.6 details | lakeat | OpenFOAM Running, Solving & CFD | 42 | August 26, 2009 21:47 |
assemble matrix in fem | ztdep | Main CFD Forum | 0 | September 14, 2008 12:30 |
convective stiffness matrix for FEM | Juergen Kertz | Main CFD Forum | 5 | December 23, 2005 05:55 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 18:28 |
