command to link fortran and c object
Old   May 4, 2001, 15:53
Default command to link fortran and c object
phuang
Please help me what is the command in PC to link fortran and c object to create an executive file. I have a program written in fortran and c.
Old   May 4, 2001, 17:22
Default Re: command to link fortran and c object
andy
The program that performs the operation is usually called a linker. On unix the command is "ld". It used to be "link" on PCDOS many years ago but I do not know how to perform the task by pointing and clicking at windows these days.
In addition, you will have to make sure all the Fortran and C libraries are linked in, the Fortran calling C and vice-versa naming conventions are followed (usually by adding underscores) and the convention for passing Fortran strings is followed (Fortran passes a pointer and a length, C just the pointer - usually the lengths are collected in order and placed at the end of the argument list). Mixed I/O can be a problem on some systems. Some systems prefer main to be in Fortran while others in C. The task is not wholly straightforward the first time and varies from system to system.
Old   May 4, 2001, 23:47
clifford bradford
Yeah it's a pain in the ass. I had to do this once for visual C they recomended compiling individually then linking w/ visual C.
Old   May 5, 2001, 03:27
D.M. Lipinski
To be able to link Fortran and C, watch the following rules during compilation. 1. For Fortran sources: use compiler switch to add underscore to all external names. 2. For Fortran sources: use compile switch to generate all external names in lowercase. 3. Make sure that you pass arguments by reference (pointers) between C and Fortran. 4. Avoid passing character strings between Fortran and C. If you must do it, read the documentation on how your compilers pass (and expect) characters in the parameter list. Besides the character string, its length should often be specified.
Now you can link the object files with the linker.
DML
Old   May 5, 2001, 21:22
John C. Chien
(1). I had looked into this kind of mixed language programming long time ago. But my conclusion was, try to avoid it by all means.
Old   May 10, 2001, 06:06
Kike
Dear PHuang
After you had read all the messages in this thread try this
(1) to compile your C source
cc -c c_source.c
(2) to link it with your fortran code
f77 f_source.f c_source.o
I agree with JCChien, avoid this
Best whishes
Kike
Old   May 17, 2001, 15:47
phuang
I can not avoid link c with fortran, because some cfd softwares are written in fortran and c. Normally they are linked by makefile in SGI. Can we create makefile for PC?
How to link Fortran to Star-CD lunar1984 Siemens 0 September 13, 2011 10:16
How to link Fortran to Star-CD lunar1984 STAR-CD 0 September 13, 2011 10:02
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
How to link my fortran program to UDFs? Sam FLUENT 0 October 29, 2008 03:57
link c++ with fortran object Pao Main CFD Forum 0 July 17, 2002 17:51
