on the validity of poisson eq's solution
Old   June 22, 2001, 13:32
Default on the validity of poisson eq's solution
yfyap
i am solving a poisson equation with neumann boundary conditions: d^2[phi]/dx^2+d^2[phi]dy^2=S define: delta=d^2[phi]/dx^2+d^2[phi]dy^2-S after i obtained the solution, i computed delta(as defined) for the entire domain. is the solution still valid if the magnitude of one of the deltas reaches 0.02 as it should be far smaller than that(approaches 0)? any opinion or advice is welcomed. thanks regards, yfyap
Old   June 23, 2001, 17:16
Default Re: on the validity of poisson eq's solution
John C. Chien
(1). If the Left-hand side Is Equal to the Right-hand side, then obviously the solution is valid because it satisfies your equation. (2). If the Left-hand side Is Not Equal to the Right-hand side, then your definition of delta will be Non-zero. Thus, the equation is Not Satisfied. That also means you are not getting the right solution to satisfy your equation.
Old   June 25, 2001, 06:22
Kike
Dear YFYAP
This is not a simple question. My suggestions is: Check it with experimental data or another numerical results (another code or researcher).
2% error is maybe good enough for your case but it could be dramatic for the Challenger, that depends on your case's requirements.
You can have 0.01% error and your results can become useless becuase your definition of the RHS (ie. S in your eq.) do not match with the physical model that your case need.
Regards
Kike
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates prapanj Main CFD Forum 2 July 30, 2011 19:07
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
Steady solution from Transient simulations wawa FLUENT 2 November 9, 2010 17:44
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
