Lattice methods
Old   July 16, 2001, 08:11
Default Lattice methods
Mark Render
I lately come across an alternative method of solving fluid problems. (instead NS-equations) These methods are called lattice methods an calculate the paths of descrete particles on molecular scale.
Could someone give a comment on that technique compared to the traditional way by solving the Navier-Stokes equations ?
Regards,
Mark
Old   July 16, 2001, 11:45
Default Re: Lattice methods
Herve
I have come across this method recently as well. It is based on Lattice-Boltzmann theory for gases i think. the example I have seen worked reasonably well, but only in the simplest configuration...
Old   July 16, 2001, 12:18
sylvain
A quick search on the web will give you the answer. I did so, and I find :
http://www.ph.ed.ac.uk/~jmb/thesis/tot.html
which seems to give a good introduction to the method.
Moreover, Powerflow from exa corp (www.exa.com) use this method.
Regards,
Sylvain
Memory requirement for lattice boltzmann methods (simple BGK) amaal Hardware 0 January 18, 2011 11:14
Lattice Boltzmann Methods for Shallow Water Flows phy4me Main CFD Forum 0 November 16, 2010 10:56
Difference CFD, Panel methods & Vortex lattice? mimi Main CFD Forum 0 December 7, 2006 09:51
boundary conditions for lattice Boltzmann methods Frederik Main CFD Forum 0 July 22, 2004 13:17
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 18:28
