momentum thickness
Old   September 5, 2001, 12:09
Default momentum thickness
Mark Render
I have got result files from a flow over an airfoil with standard k-eps-model with wall functions. Is it possible (and senseful) to calculate from the results the momentum thickness at certain chord positions ?
Regards,
Mark
Old   September 5, 2001, 12:56
Default Re: momentum thickness
John C. Chien
(1). Assuming that you are not interested in the wall function region, then some kind of interpolation is required because the momentum thickness is defined in terms of the boundary layer coordinates. (in this case, it is normal to the local wall)
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 14:38
Calculating displacement and momentum thickness from Fluent VSAndroid Main CFD Forum 0 April 14, 2011 13:45
How can I compute Cf and Momentum thickness in fluent? M.Sc_Student FLUENT 0 June 19, 2010 14:42
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
momentum thickness Feitoudaer Main CFD Forum 0 April 29, 2008 13:32
