Transformation to change the instability?
Old   August 9, 2001, 22:44
Default Transformation to change the instability?
Yi, Li
hello,all: I have met a equation like dx/dt = x + b(t) in my work. b(t) is a term that counteracts the instability of the first term in rhs, and is interpolated from experimental data. But it was found that the solution is very sensitive to the values of b(t). Can I transform x to another function to reduce the instability? Urgently! Thank you all.
ps: The problem arises in the context of the mixing model of PDF method, and I met many more problems on this aspect. Hope to discuss with all of you, if you were working on it as well.
Old   August 14, 2001, 00:31
Default Re: Transformation to change the instability?
John C. Chien
(1). Try to reduce the dt when x gets larger.(2). It is a log function, or exponential function behavior.
Old   August 14, 2001, 04:41
Yi, Li
Thank you, John.
How to change density in OpenFoam zhaowei OpenFOAM Running, Solving & CFD 8 November 5, 2018 10:37
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 09:40
Instability in phase change computations quicksilver Main CFD Forum 5 June 6, 2009 10:25
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
