Rotating Flows and Ekman BL
Old   February 1, 2002, 19:32
Default Rotating Flows and Ekman BL
David Stanbridge
We are trying to resolve a highly swirling field with swirl numbers approaching 7. With the RSM model the results do not match well with measured values. An author has commented that an Ekman layer forms as a result of the swirling flow in a tapered body. Eventually this leads to flow separation in the body which was actually seen in practice. As anyone else experienced this? We are now thinking about running a LES model with a grid of around 0.5 mm but am doubtful if this is fine enough. Again has anyone had experience with high swirl numbers and the LES model?
Old   February 2, 2002, 02:50
Default Re: Rotating Flows and Ekman BL
Atif hassan
Hi I am a student of mechanical engineering.I want yo know that What is CFD?
If you provide me some help or informative links on this subject I shall be thank full to you. Atif
Old   February 6, 2002, 02:00
Asok
Do you mean the Taylor no. as the swirl number or it is different.
Old   February 6, 2002, 03:27
David Stanbridge
I mean the swirl number.
Old   February 6, 2002, 23:14
Asok
Does the swirl number concerned with eddies/vortices.
