Poisson-type equation
Old   February 7, 2002, 09:13
Default Poisson-type equation
Ammar
Hi, I am trying to solve the Poisson type equation for the pressure on the form:
del2(P)-C(x,y)*grad(P)=f(x,y)
If I wanna descretize this equation, should I deal with the higher derivative terms only and consider the lower derivative terms as a source term? I mean (for 1-D case):
d2P/dx2 = C(x)*(dP/dx)+f(x)
Any specific method to solve this type of equation?
Old   February 7, 2002, 13:02
Default Re: Poisson-type equation
Jim Park
Since this is a linear equation, I'd be tempted to descretize the entire equation (first and second derivatives), then solve it using Gaussian elimination. You'll get a banded coefficient matrix (unless you have periodic boundary conditions which can complicate things a bit), which is pretty efficiently stored and solved. There may be a conditioning problem for the matrix if C is too large.
Good luck!
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
SST SimpleFoam Convergence Problems camoesas OpenFOAM 23 September 27, 2011 16:27
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 06:22
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 15:12
