Node-Based and Cell-Centred Patterns
Old   April 7, 2002, 06:26
Default Node-Based and Cell-Centred Patterns
Konstantin
What deficiency and advantage have node-based and cell-centred patterns for control-volume discretisation of transport equation on unstructured grids ?
Old   April 8, 2002, 14:19
Default Re: Node-Based and Cell-Centred Patterns
FRED_PSU
Well, for the same tetrahedral mesh for example, you get to compute the solution at 5 times more points using cell-centered calculations compared to vertex centered methods: more CPU time, more accuracy, more memory requirements,... it depends on what price you want to pay for your runs. With a cell-centered formulation, the control volume is straightforward: the cell volume and faces. Otherwise, you have to define faces that separate nodes, etc... I think CFX5 is node centered for instance...
Fred.
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
Diff b/w node based & cell based methd Murthy FLUENT 0 April 2, 2008 13:18
which is better? vertex based or cell centered? neil Main CFD Forum 1 April 23, 2007 16:54
node based or cell centered Ts values acboge FLUENT 0 February 6, 2004 06:41
Cell Vertex Based FVM A. S. Main CFD Forum 1 January 28, 2002 07:46
