Which Turbulence model to be used?
Old   May 2, 2002, 08:55
Default Which Turbulence model to be used?
Lego
Hello!
Would anybody summarize me, which turbulence model to use in several problems?
In case of the high Reynolds-number flows the k-epsilon or k-omega model is suitable?
Gratitude: LEGO
Old   May 3, 2002, 08:24
Default Re: Which Turbulence model to be used?
Tim
It would be helpful if you outline the cases you wish to simulate. In general I believe the most accurate RANS turbulence models for a wide range of flows are the V2F developed by Prof. P. Durbin (Stanford) and the Wilcox K-Omega model. (+ I beleive there have been a few advance proposed on this model lately). If you are using a commercial CFD package you will probably be limited the one of the turb models in the code (unless you wish to implement one yourself?).
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
