CFD software for conjugate heat transfer
Old   May 24, 2002, 07:44
Default CFD software for conjugate heat transfer
lengzi
What are the CFD packages that are specialized in general conjugate heat transfer (conduction, convection, radiation) ? Thank you.
leng
Old   May 24, 2002, 08:25
Default Re: CFD software for conjugate heat transfer
Amita
Check out fluidyn-CHT on the Website www.fluidyn.com
Amita
Old   May 27, 2002, 10:37
Arnold Free
MAYA provides a complete integrated thermal solution, including conduction, convection and advanced radiation (diffuse, specular, including ray-tracing) modeling capability with it's advanced CFD solution.
See www.mayahtt.com.
Old   May 28, 2002, 05:37
John YL
Any major CFD packages advertised in this forum should be able to handle.
Old   June 21, 2002, 14:33
Ethan
Just about any of the CFD codes can handle the conjugate HT but each has strengths in different areas. What applications or time involvement are you looking at?
Old   July 1, 2002, 10:53
lengzi
Ethan:
I am looking for application in small scale non-rectangle geometry (a few hundread microns) such as optical fibers. Do you know which CFD package has the strength is this area ? Thank you.
lengzi
Old   July 1, 2002, 11:21
Ethan
If you are tasked to do this type of analysis as a primary job function and the focus is on small details like the fiber you may want to consider a general purpose code like Fluent.
Otherwise if you are looking at an opto-electrical module or package you may want to consider a code like Flotherm since it offers some ease of use and business advantageous when working with customers.
I suggest taking a look at the web pages and request them to come out a do a demo or better yet take a trial. Most vendors will provide you with a short period to evaluate the software. After all almost any code can get the answer right it is just a question of how much work it requires from you to get there.
Old   July 5, 2002, 10:53
lengzi
Thank you. Ethan
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
benchmark for heat transfer in CFD Ralf Schmidt Main CFD Forum 0 March 28, 2006 02:47
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
