August 5, 2002, 00:17 |
mixing length model
Hi, In mixing length model eddy viscosity is propotional to mean fluctuating velocity, but mean fluctuating velocity is always zero. So every time eddy viscosity is zero but it is not the real case.I am not right but what is correct plz tell me thanks
August 5, 2002, 13:21 |
Re: mixing length model
This seems to be a case of confusion caused by imprecise use of jargon. The mean fluctuating velocity is zero, but what goes into the mixing length model is some measure of the magnitude of the fluctuations, such as the root-mean-square average.
August 6, 2002, 00:02 |
what do you mean by "caused by imprecise use of jargon" can you tell me what is the mixing length, characteristic length and characteristic velocity
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
mixing two fluids using mixture model | fadhil | FLUENT | 0 | June 9, 2008 01:28 |
Interfacial length scale in mixture model | Andrew | CFX | 3 | December 30, 2002 08:38 |
Mixing plane model | Antoine Ringo | FLUENT | 2 | July 30, 2001 08:25 |
